Open a soild USB flash?
Hi all
Here is my problem, I have a "super talent" USB that it’s badly bended one day and the result is that somewhere inside there is a bad connection. I’ve tried to open it but it seems that it’s bonded solid with the circuit. Any ideas what can I do to open it? Is there a chemical solution?
Thanks
Paul
Picture of Open a soild USB flash?
pavalos (author) 6 years ago
Thank for quick response but the problem is that there is not any plastic housing; the PCB is its cover!!
Kiteman the USB is not dead it says USB not recognized... that’s why I will give it a try
kevinhannan6 years ago
when friends have brought me their bent and broken usb sticks to look at, without exception the break has always been exactly at the junction where the 4 copper terminals are attached to the innards by solder. have a look there in your first instance.
With nothing to lose, I'd be tempted to use a fine soldering iron point and melt the plastic at the junction point I talked about but be careful of damaging the components throught the heat - don't just apply forever until it melts through - use a bit of judgement about it ;-)
another place I'd start is using a very fine saw at the copper terminals end, stopping where the terminals meet the innards.
you might also try to break the bond/seal along the edge using either a cutter or heat and use a flat blade to help prise the plastic housing apart. (oops, as Kiteman sez!)
good luck.
Kiteman6 years ago
If by "bad connection", you mean it's dead and useless, it's worth risking power tools.
I would use a cutting disc on a rotary tool and cut around the edge of the memory stick, then prize apart with a short blade.
