loading
PETTY COIN BANK- initial stage. Can anyone help?
hey Guys... need some advise and help on the initial idea and components of this project.
PETTY COIN BANK:
PURPOSE:
- To electronically segregate coins, display the total number of coins per each case and the total monetary amount inside, with dispensing and security capability.
FUNCTION:
- Individual coins inserted in the coin slot will be segregated to go to the corresponding individual coin cases and each case will count and display the number of coins dropped in them and a general display for the total amount of money inserted in the device. With a security lock, the device is capable of dispensing coins.
so What do you think?
Some advise on how i can make this possible...
I do have some ideas on the segregation and dispensing mechanisms of the project, and how to identify each of the coins from each other when inserted in the coin slot.My concern would be the Displays for the each NUMBER OF COINS that falls per case (3 displays in total), and the TOTAL MONETARY AMOUNT display that counts per inserted coin in the system. Of course when dispensing, the number of coins should be decremented and the TOTAL MONETARY AMOUNT would change as well depending on the coin and number of coins dispensed.
And as you might have read from the purpose and function, this project intends to have a security lock for the dispensing mechanism. Anyone can put coins but only someone that knows the code can dispense coins. I plan on putting a keypad for that. but here is the thing...
I DON'T KNOW WHAT MICRO-CONTROLLER I SHOULD USE.
I plan on using ARDUINO, but what arduino should i use? and if someone can help i'd like a count of the inputs and outputs so i can decide on what to use.
Thanks if someone helps on this...
rickharris4 years ago
Assuming your not going to put counterfeit coins in your own piggy bank I guess the easiest way is to mechanically sort them by weight or size.
Most of the high tec solutions are an effort to exclude bad coins.
