3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
PICAXE Ciruit Help needed! I'm trying to figure out why my circiut is not working. Can anyone help?
Note: I have attached a copy of my programming and the schematic of the circuit.
As part of my school systems engineering course, I have decided to build an automated chook shed door. For the electronic side of this project i'm using a PICAXE microprocessor (PICAXE 08M - to be exact) to control the up and down operation of the door - which is done using a 12 volt linear actuator, all powered by a 12 volt battery (eventually to be rechagred by a solar panel). My theory is to basically read in the light level using an LDR and then based on this level to open the door, or close it. The is designed to work through the use of 3 relays (all with built in diode protection). The first relay is connected to the 12 volt power which supllies power to the other set of relays, and in effect the actuator, when ouput 0 is turned to high (I'm using transistors to do this as seen on the in the shematic). When I want to reverse the the motor I again turn ouput 0 to high, but also ouput 1 to high which switches the the other coupled relays (again using a tranistor) and in effect the polarities of the actuator.I'm also using two microswitchs on the bottom of the vertical sliding door as a safety mechanism, so that when the door is closing and an obstuction occurs (i.e a hand or piece of wood), its programmed to lift the door for about a second before trying to close again.  As mentioned before it acts a safety mechanism so that no little fingers can be chopped off, and the actuator it self doesn't overload and blow up (although I'm pretty sure it has inbuilt protection for this anyway).
Ok anyway to the problem, I have wired everything up as to the schematic I have provided, and loaded the program onto the chip (which it does successfully do) - however its not performing as desired. I have placed the same program onto another identical PICAXE system (except it is not obviously connected to all of the stuff mine is) and it works fine. I have also tried reducing the complexity of the program and taking out the LDR readings in the code, and when I do this,  it does successfully turn on the relays as desired. For some reason it appears that the LDR is reading a full light level even when I place my finger over it, and because the IF statment in the program relies on a low LDR to operate, the code which turns on the relays never gets to execute.  At first it seems that there may have been a problem with the LDR, so I changed it  with a new one, but again it continues to read the highest value of 255 (or 1 byte) and therefore the program never executes as desired. I'm not sure why the LDR keeps reading the highest value. CAN ANYONE HELP!
Jun 27, 2011. 3:13 PMAndyGadget says:
From what you say it sounds like you've narrowed it right down to the LDR circuit.  It sounds like the ADC input is shorted to 5V - Have you tested for this with a resistance meter?  If it's a short, check and re-check the wiring, especially for solder or wire whiskers between tracks. Also check the value and for dry joints on the resistor to 0V as an open or way too high value would have that effect.
If all is OK, replace the LDR with a variable resistor and see if it works manually adjusting the 'light level'.
Jul 5, 2011. 11:26 PMAndyGadget says:
Thanks for Best Answer. Glad you got it working.
Chook shed doors appear to be fairly popular thing to apply the PicAxe to. A small controller like that is ideal for that sort of task. And the 08m2 has just been released - Check the PicAxe forum.
Jun 27, 2011. 2:38 PMrickharris says:
See if you can work out how this works - simulates OK
Main:
'assumes pin 3 has micro switch fo door closed
'Pin 4 has micro switch for door open
'output 1 high output 2 low opens the door
'output 1 low, 2 high closes the door.
'ADC writes to B1
' runs in Picaxe 08.
B0=1 ' door closed flag
b1=152
check:
if b1<150 then opendoor
if b1>151 then closedoor
sleep 1000 ' low power mode for 16 mins no need to check light often
goto check
opendoor:
if B0=1 then goto check 'check flag
high 1 ' open door
low 2 ' open door
checkstopopen:
if pin4=1 then stopmotor ' door open
goto checkstopopen
stopmotor:
low 1
B0=1
goto check
closedoor:
if B0=0 then goto check 'check flag
low 1
high 2 ' close door
checkstopclose:
if pin3=1 then stopmotorx ' door closed
goto checkstopclose
stopmotorx:
low 2
B0=0
goto check
Jun 29, 2011. 10:47 AMrickharris says:
As steve said you need to measure the voltage at the LDR/resistor junction i.e. the input to the picaxe ADC. Cover the LDR Uncover see what you get and report back.
Jun 27, 2011. 12:18 PMsteveastrouk says:
Measure your LDR resistance, dark and light, and report back.
Steve
Jun 29, 2011. 1:45 AMsteveastrouk says:
No, that isn't the equivalent. Stick an ohm-meter on your LDR and report the light and dark readings. From that, I can get a better idea what's wrong.
What happens if you open circuit the pin ? What happens if you ground the pin ?
Steve
Jun 29, 2011. 2:59 AMsteveastrouk says:
Its not generally a good idea to have the computer have sole control of the motor hardware. Its much safer to have limit switches that directly interrupt the relay current, like this circuit I did for another 'ibler.
Steve
Jun 27, 2011. 10:43 AMrickharris says:
Your going to get a much better response from the Picaxe forum http://www.picaxeforum.co.uk/forumdisplay.php?f=2
However your relay connections look rather funny. In general it is usual to use a "standard" H bridge set up if your going to use 2 relays. like this.
Jun 27, 2011. 10:48 AMrickharris says:
You can perhaps make the programme a bit simpler by setting a "flag" to show the door is open
example:
B0=0 ' door closed flag of not open must be closed
check:
Check daylight if > set level then open the door else close the door.
open:
B0=1 ; set door open flag
rest of code to open the door.
Close:
B0=0 ' set door closed flag
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
