PPowering 12 volt car radio with solar panel?
My friend has a bass boat that he wants to put a car radio into. However, the boat motor has no alternator or dynamo to charge the batteries. Is there a solar panel available that would keep the radio and two 6.5 inch speakers going on his boating trips. He is usually out 3-4 hours at most.
Yonatan245 months ago
Can you please give less information? It's too confusing...
(hint-hint)
ShawnI7 (author)  Yonatan245 months ago
My friend has a boat, but motor doesn't have charging capabilities. He wants to put a radio and one pair of speakers in boat tho. Can a solar panel be used to keep the system charged?
iceng ShawnI75 months ago
Best fishing occurs on cloudy days in mornings and evenings..
Does he start his "boat motor" with a push button ?
Car radios use a great deal of power compared to radios that have a built in solar panel and or maybe windup mechanism..
The audio speakers will penetrate sound into water as does a slapping fish line.. -.-. . -. --.
ShawnI7 (author)  iceng5 months ago
he is wanting more for leisure trips up the delta. Won't use it on his fishing days. He does use button to start engine tho.
Then there is already a 12v battery somewhere in the boat too run the starter motor which the boat Internal Combustion motor recharges while motoring..
Still car radios suck power.. Try to find a portable radio with good antenna because radio reception at the lowest point in the area is not RF worthy..
And keep a weather eye out for distant lightning dark clouds.. -.-. . -. --.
type very much for ur advice.
If this helped you then you can click the Best Answer.. -.-. . -. --.
iceng iceng5 months ago
When you find that starter battery the ignition noise may need to be filtered out using a pi filter C-L-C or a corcom between battery and radio see a boat shop for noise filters.. -.-. . -. --.
