Passing lesson to 100% - workaround/solution?
To all of You having problems with completing the lesson (I also had). Here is a hack to do it, I hoipe You can follow.
Indeed there is a second question which is not rendered correctly.
- Right click on the first question somewhere inside the box.
- Pick "Inspect element" from context menu (or something similar depending on the browser You use).
- A toolbox-side window will open with the HTML code of the Instructables website in the place where You inspected element.
- SOmewhere next to it You should find 2 entries like this: <pre class="quiz-json">
- Click one of them to select it.
- In "Styles" section You can see a part: .quiz-json { display: none;}
- Unselect "display: none" CSS value. The second question (with wrong rendering but still readable) should appear on the website. Question is about the picking the strongest password "muffins" related.
- Choose the correct answer and click the "Answer" button.
- You should have now 100% for Lesson 1.
Good luck.
