loading
Photoshop CS6 Timeline
I have used Timeline a lot in photoshop CS5.5 but when the new version Photoshop CS6 came out the button on the bottom right cornor to change from frames to seconds was gone. (first image is what i have,second is what I want.)
Picture of Photoshop CS6 Timeline
canucksgirl4 years ago
I'm sure you realize that the timeline has changed... That being said, open up a video that you want to work on, and then inside the timeline area, you'll get a button that says "create video timeline". Click on that and it opens up the timeline of the video. You should then see all your options.
Let me know if you still need help. ;-)
iproberry1 (author)  canucksgirl4 years ago
you mean import a video right?
You can drag and drop the video in, or import it. Then you should see in the timeline area a new button for "create video timeline".... lots of changes. :-|
so i imported and this:
Okay, do you see the drop down arrow right above frame 18?
Click on that and then select "convert to video timeline" and you're there.
nope...no "convert to video timeline".
I did some reading, and found a thread where someone else had the same issue. They had to uninstall and re-install the program to fix it... no one could figure out why the option to "convert to video timeline" wasn't there.
well....ok, thanks!
No problem... sorry it wasn't the answer you were looking for, but for whatever reason, its happened before.
You have the right options-menu, its just that the option to convert it isn't there...
See image.
also...can you send me a link on what you searched?
I had found a few, but here's one from adobe...
same problem is happening with me
please help me.. if some one can..
I was using CS6 itself.. and i was having the time line option .. but then suddenly it didn't opened one day i uninstalled and reinstalled and it didn't work.. and the 3D feature is missing from the software :'(
