Physical button to launch a PC application?
So for an upcoming project I need to make a physical button that when pressed launches an application on my PC. I'm going to need to make quite a few of these, each to launch a different app. Ideally it would not be a keystroke from a keyboard, I saw tutorials on dismembering a keyboard and registering a button press to open an app, but I don't want any interferences so I'm looking to avoid that if I can. I'm going for the most cost effective design, not looking to spend much if it can be helped. Any resources or tips would be much appreciated! Thanks guys!
Atul0094 years ago
hoping u know to program
u can input base 2 with parallel port the library used for it should be inpout32
make a program without a window that read the port input and launch application when value change from 0 to 1.
Hey, Parallel ports, I remember them. Not seen one on a PC for years.
yeah they are out dated but with a usb to lpt connector things can be very easy
Arduino Leonardo. Job done.
You could use the keyboard hack but have the program launch with a combination of keys. So your single button press triggers the key combo.
have you looked into shrimpkey? its an open source makey makey?
