3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Picaxe 08M Porgramming Troubles??? (STILL NEED HELP AS OF TODAY)
Hi all. I just got a Picaxe o8M and a Picaxe 08 Proto Board. I have used it successfully, but ever since I used it on my OTHER pc, I wasnt able to program it with my newer pc. Now I cant program it at all... WHAT TO DO??? The hardware works fine. I am using a SERIAL cable. And YES, I DID have the head pin thing o the prog. position. PLEASE HELP!!! THANKS!!!!!
Jun 25, 2011. 1:20 AMrickharris says:
1. You know it works.
2. Does it still work on the other PC
3. The picaxe08 hasn't changed - unless you have made a considerable effort to erase the boot programme (not easy)
4. Check the com port is active
5. Try downloading with picaxe turned off and when you see the down load bar turn it on.
6. You will get much better support from the Picaxe forum at http://www.picaxeforum.co.uk/
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
