Piezo buzzer for LED flasher?
I have built the flasher found here; https://www.instructables.com/id/LED-Flasher-automotive-or-motorcycle/ It works great with the LED turn signal bulbs on my bike I would like to hook up a piezo buzzer to the flasher that buzzes when either the right or left signal light is on (motorcycle flasher reminder buzzer). What would be the easiest way to do it? The flasher runs constantly when the key is on, only powering the turn signals when the turn switch is activated right or left. The buzzer won't work when hooked up to the B+ and load terminals like it was on the mechanical flasher with incandescent bulbs. I figure the problem is that the incandescent bulbs provided the ground for the buzzer though the filaments. Does this sound right? Thanks. Sorry about the long diatribe.
AndyGadget8 years ago
Add two diodes as shown so that the buzzer is energised whenever one of the indicator LEDs in activated.
AndyGadget, will that work with an automotive circuit, say an '85 Volvo 240 with electronic turnsignal flasher but incandescent bulbs? I remember the old Champion Auto Parts stores used to have a simple fuse block clip-on piezo buzzer for turnsignals but I never bought any. Wish now I had. Windows down, can't hear the turn signal click or see the light during the day. This would be a great answer.
As long as you've got 12v switched to the bulbs by the flasher stalk you should be able to use this circuit. It won't work if the bulb is permanently connected to the positive and the stalk switches it to ground, but I don't think many vehicles are wired that way as it means less wiring if the indicators can have one side connected to the chassis (ground).
Thanks, Andy, I'll give it some more research. Not sure how my Volvo's wired but it should be rather simple. I know I don't have a thermo flasher. It's the new style electronic flasher. Will that make a difference? I'm not sure of the flasher wiring but I keep thinking there must be a way, when the flasher is energized to either of the turn circuits, right or left, if a voltage could be taken from the flasher output to fire the piezo buzzer regardless of which circuit the turn signal stock selects. If the piezo wouldn't draw too much current and screw up the flash sequence. My thought would be that wiring it that way would be somewhat simpler. If it would work.
Normal piezos are very low current, so aren't going to affect the flasher operation. I can't find a wiring diagram specifically for a 240, but looking around a bit, the commonest arrangement seems to be : 12v . . . flasher unit . . . flasher switch . . . indicator bulb . . . chassis. If it's an electronic flasher you may be able to just put the buzzer on the output of the sounder unit and not need the diodes. The difference is that a thermal flasher output will be at 12v when flashers are off, whereas an electronic flasher unit will be at 0v and only pulse to 12v when the switch is operated.
That's my thinking and what I'm hoping. Will let you know the results.
pofarm (author)  northerner310b8 years ago
This is the set up I used with the electronic flasher I built (link in my 1st post) and LED turn signals. It works great. Thanks, AndyGadget. It should work with any type of flasher system, I would think.
pofarm (author)  pofarm8 years ago
BTW, I have used these buzzers on older bikes with bi-metal flashers, also. Some bikes came with them from the factory. They used to be a fairly common aftermarket add on, too. They connected directly to the flasher between the B+ and load terminals. There are two reasons I couldn't connect one to the home made flasher like this. First, the way the flasher is made, it cycles constantly as long as current is supplied to it which, in this case, is anytime the key switch is on. The second reason is because the bulb filaments provide the ground for the buzzer, which you can't get with LED's.
el.lori6 years ago
LED ALADDIN Limited
All light sources in our houses or at work must give an appropriate amount of light depending on the type of activities we perform. While working on a task that requires medium concentration the illuminance in a room should be at least 300 lx. The desks and keyboards while working at a computer should be illuminated with about 500 lx and while performing tasks that require high precision and concentration the luminous flux density should be about 750 lx. For comparison the amount of light that is enough for relaxing and watching tv is about 20 lx. Under this value the human eye is not able to recognize the features of a face.
Examples of suggested illuminance in rooms
Living room
1.main lighting: 100-200 lx.
2.surface of a table for reading and writing: 300-500 lx.
3.dining table: 300-500 lx.
4.computer stand: 500-750 lx.
Kitchen
1.main lighting: 200-300 lx.
2.under shelf lighting: 500 lx.
Other rooms
1.hallways, stairs: 50-100 lx
2.bathroom and toilet: 300-500 lx
Other exemplary values
1.facial features recognition: 20lx.
2.sunny day: up to 10 000 lx.
Multifunctionality of lighting
While designing lighting in a house or flat it is important to keep in mind, that very often one room is used for many different kind of activities. For example a living room is a good place to relax and watch TV (where a subtle, slightly diffused light is most appropriate) but also for family meetings and meals for which the luminous flux density should be about 300-500 lx. This is why we should not limit the light sources to only one, but to few different lighting points that can work independently from each other.
Many sources of light in one room
Due to the fact that most of the rooms in our homes are used for different activities, it is suggested to use multiple independent lighting circuits. A very good solution, that is more and more popular in interior design, is diffuse lighting. Diffused light may be produced both by a reflection of light from a completely nonspecular surface and by using multiple small point light sources.
Energy efficient and environmentally friendly
While designing the lighting in a house it is good to choose light fixtures that can work with energy saving light sources. This environmentally friendly lighting not only helps to save money, but it is also shows our care about the environment.
Good quality light sources
We should always remember to choose good quality light sources. Very often a theoretically cheaper light source is actually more expensive because of its shorter lifetime and because its performance is much lower than stated by the manufacturer.
Contact LEDaladdin
LED Aladdin Limited
No.406 HongTeng Building,
No.392# Xihong Rd,Gulou.
Fuzhou,Fujian.
350002
China
Tel. : +86 591 6310 1956
Fax. : +86 591 2285 5952
E-Mail : info@LEDaladdin.com
WEB: http://www.ledaladdin.com/index.html
