Please explain Theo Jansen Mechanism?
We all have seen the Theo Jansen Machines and they are JUST AWESOME!
I'm trying to build one.
What is the the theory and mechanism behind Jansen's machines?
Please explain.
[Unicode Symbols for your convenience:
Degree= ° , Half = ½ , Third = â��, Fourth = ¼, Three Fourth = ¾ , Integral = ∫ , Differential = ∂, Delta = Δ , Square = ² , Cube = ³ , Square root = √, Cube Root = â��, Infinity = ∞, sum = ∑ , Therefore = ∴, Because = â�µ,]
Nov 19, 2011. 12:43 AMrickharris says:
A relatively simple 4 or 5 bar mechanical linkage. The movement is created by the relative lengths of the struts - Your best bet is to study the many youtube videos of these mechanisms - There are animations out there that show it clearly.
http://www.youtube.com/watch?v=CufN43By79s
http://www.youtube.com/watch?feature=fvwp&NR=1&v=PWm4VMR8D0w
http://www.youtube.com/watch?NR=1&v=NM4q-f68TlY
Nov 19, 2011. 9:53 AMKiteman says:
What do you want explained?
If you want to build one, look at the Jansen walkers already on this site, or take the measurements from Jansen's site or videos.
Nov 19, 2011. 11:49 AMKiteman says:
Even Jansen himself says that the best way to explain the leg is to make one.  The "maths" of getting the leg right was pure experimentation, thousands of iterations to produce the now-classic proportions:
Legs
The real trick is the energy system
Apr 20, 2013. 9:50 AMMr.What says:
AFAIK, Jansen employed some random searches (of linkage lengths?) and optimized the base linkage. The tricky part was coming up with the base linkage. From there optimizing by computer is relatively straightforward. Here is a thesis by a person who optimized this linkage with different criteria, creating a superior linkage for some applications:
http://www.amandaghassaei.com/files/thesis.pdf
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
