Powered USB hub that doesn't power from the PC if its available first ?
I've tried a standard hub, and cut the USB +5 from the PC, which stops the things ennumerating sure, but they don't ennumerate when you plug the power in !
I suppose I COULD put a signal relay in, or logic that would do it, but something off the shelf would be better.
TIA gang
8
answers
Answer it!
http://www.dealextreme.com/details.dx/sku.31864
. What I had in mind is replacing the power plug/jack on the hub with something that has a built-in switch. When the power jack is unplugged, the switch kills the 5V from the computer.
I've got a unit where I've consolidated all 7 USB items into one hub. The unit is sometimes not switched on when the PC is, it would be a real PITA to have to disconnect the USB cable each time its used.
Steve
If you want it to stop enumerating, usb is hot plug, and the computer is relatively dumb to the power lines (other than current limiting), so run the data lines through a physical switch. To automate things, make that switch a low voltage relay powered by the incoming power from the wall adapter. power on, connects usb data, computer sees device. Unplug, and it disconnects.
Agreed also that a ready-made solution would be best, but I can't suggest any specifically for this behaviour.
http://www.dealextreme.com/forums/Forums.dx/Forum.-210~threadid.557697
