3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Powering a 12v DC fridge ?
Hi, I have a 12VDC fridge and am trying to convert a computer power box to supply power to it.
I started with a ATX type and have problems with it resetting itself after the compressor restarts itself after reaching temp. I have a 10Watt resistor connected to the 5V wiring to keep it running during full temp switch off, but when frigde restarts itself the power supply resets.
I am now trying a AT 230W box and it does not reset but under load I only get 10.4v, not enough to operate fridge for cooling.
Any sugestions how to lift voltage as when connected to motherboard and 4 hdd's it generates 12v.
Sorry I should add that the fridge is 12v 4.2amp and the power box is 12v 8amp. I have tied 2 x AT type boxes with same result.
Thanks Tim
Thanks
Feb 24, 2011. 9:08 PMZerocool818 says:
if its a pump operated one it wont work as Re-design said but if it is a peltiair one it should work as its just a chip i know i have a small one that can stor like 9 cans of soda and it came with a 5 amp adapter 50 watts i got it for a dollar at a garage sale. i cut off the connector halfway and now i can use it in my car with a adapter!!
Nov 30, 2009. 8:07 AMseandogue says:
Stall current is much larger than quiescent.
one method for determining the stall current required for your application is outlined here http://combots.net/wiki/index.php/Stall_current
Nov 30, 2009. 6:28 AMRe-design says:
When the compressor starts up it draws a lot more power than when running.  Computer power supplies probably don't do well in a surge situation.  I would think that's your problem.
Can you find out what the surge is on compressor startup?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
