Problems with the 4511b IC chip??
SO i made a circuit which is a binary adder(using the 4008b) that adds numbers in binary and then passes on the result to a 4511 IC(its a BCD to 7 segment decoder),so basically it adds numbers in binary and displays them in decimal .It seemed to work fine for a while but then suddenly when i tried adding
0011 +0001(3+1) in binary ,it still displayed 0 and then i tried tapping the battery for a second or two and then suddenly the seven segment display shows 4 .The circuitry is all fine and right .but do i have to connect latch enable(pin 5) pin of the Ic?.Both the IC's run on a 9v battery and for the 4511 decoder IC i used 33k pull down resistor .Is my pull down resistor value for the 4511 IC too high ?The binary adder part seems to work very well,its the bcd to 7 segment decoder IC part that I'm very much concerned about.Is there too less power for both the chips to run on?I've not got a single idea at all .so, >PLS help me if you can.
MEASURE what's going on with a meter. For 4000 series, 33K sounds OK.
Show your circuit, again. Words don't work. It could be a bad breadboard even.
