loading
Programming an Attiny85 with Arduino Uno as ISP, but I keep getting Serial was not declared in this scope?
The sketch runs fine on the uno, but as soon as I switch the board to Attiny 85, i get an error that says serial was not declared in this scope.
Any help is greatly appreciated!
Here is the sketch for reference.
#include <IRremote.h>
const int relay = 9; //Relay Control
const int RECV_PIN = 8; //IR Sensor
int relayState = LOW;
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup()
  Serial.begin(9600);
  irrecv.enableIRIn();
  pinMode(relay, OUTPUT);
void loop() {
  if (irrecv.decode(&results)){
        long int decCode = results.value;
Serial.println(decCode);
switch (results.value) {
        case 1637937167: // Power Button
      relayState = !relayState;
      digitalWrite(relay, relayState);
      delay(100);
irrecv.resume(); // Receive the next value
You can't use the SAME pins for Soft serial as the relay and the IR.
meanbean (author)  steveastrouk4 years ago
Sorry, I'm new to the softwareserial command. What pins should I set it to?
Any two other than two that are already in use for other things. Your other problem will be taking serial out to the real world - you will need a TTL serial to USB cable.
If you want to use serial, you will need to use softwareserial
http://arduino.cc/en/Reference/SoftwareSerial
You may need to modify the library itself (I seem to remember it having a hard frequency ifdef)
http://digistump.com/board/index.php/topic,212.msg1214/topicseen.html#msg1214
+1
Still no luck, although I'm fairly certain i'm using SoftwareSerial wrong
#include
#include
SoftwareSerial mySerial (8, 9);
void setup()
mySerial.begin(9600);
void loop() {
mySerial.println(decCode);
delay(100);
Now I'm getting an error originating in the ir libraries.
ok, whats the error?
See my comment below.
