Pushbutton Question
I have been taking apart Gameboys and keyboards. These devices have buttons or keys that you push to play a note. When I take it apart, I dont see pushbotton switches like id expect. Instead I see a rubber form with a little black dot on it, and when you press it, the black dot touches a black surface on a PCB. Anyone know how this works?
Oct 23, 2010. 8:43 AMsteveastrouk says:
Yes, the dot is conductive rubber. it makes a circuit with the inter-digitated traces on the PCB.
Steve
Oct 23, 2010. 8:57 AMNachoMahma says:
. +1
Oct 23, 2010. 5:30 PMfrollard says:
Agreed with steve -- conductive rubber. My old NES pads had graphite pads on bare copper (hence they wore out so fast).
Nowadays they're painted with that black conductive paint to prevent corrosion on the metal pads.
Oct 23, 2010. 10:51 AMsteveastrouk says:
No,look carefully at the board and solder from one set of fingers to the other via your switch.
Steve
Oct 23, 2010. 8:40 AMKiteman says:
Is the black surface on the pcb at all flexible?
It might be a membrane switch.
Oct 23, 2010. 8:49 AMKiteman says:
In that case they are patches of something conductive, and touching them together completes the circuit.
Oct 23, 2010. 9:52 AMKiteman says:
See Steve's comment: conductive rubber.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
