loading
Quadcopter Motor Type?
Hi,
I'm working on building a quadcopter.  I have everything figured out, but I'm wonder what motors (and where) I should get.  I would also like that motor to have a propeller mounted on it.  I have seen many Instructables for quadcopters, but none of them specify the motors/propellers.  If you could answer this, please do!  Thanks.
iceng2 years ago
I found this ible https://www.instructables.com/id/The-Ultimate-DIY-G...
which specifies the source for motors, props and helpful tips.
Good luck building.
aamc2 years ago
I am also interested in making my own quadcopter.
rickharris aamc2 years ago
read my link below
rickharris2 years ago
http://www.flitetest.com
Will give you LOTS of information videos and knowledge.
As with everything in a flying machine it all has to be balanced out. So your motor and propeller choice will depend on how much weight you have, size battery you have, and desired run time. Larger propellers cause more strain on the motors making the motor draw more amperage and reducing battery life. Some times it takes some experimenting to get things right for you build. You may have to try several differnt propellers before setting on the right one for your build.
