Quadcopter using 12V battery and Wood Screwers
I’m currently attempting to rebuild the quadcopter demonstrated in the link below:
https://www.youtube.com/watch?v=qa_x93JQhNM
The materials I have are as follows:
• SMAKN Buck and Boost Voltage Converter
• 20 AWG Flexible 1007 Wire Electric wire 20-Gauge Copper Hook Up Wire
• 2300KV 2204 Brushless Motor CW&CCW
• 12V 7 Amp EXP1270 Rechargeable Lead Acid Battery
• Carbon Fiber Propeller
• Digital Multimeter
Attempt 1:
We connected a motor to the 12V battery using clamped wire connects – there was a lot of sparking and the motor did not spin.
Attempt 2:
We connected 2 motors in series – connected the motors and the 12V battery to the buck boost convertor – which resulted in the battery smoking and the buck boost convertor burning out.
Can you watch the video and explain to me the wiring aspect to the quadcopter - I believe I may be missing necessary wires such as a female insulated connector that connects to a terminal wire which connects to the 4 motors in series but I’m not sure.
steveastrouk7 months ago
I don't see "ESC" or motor drive controller in that list of parts. Hence you shorted the motor across the battery and it blew everything.
1+
That happens if someone with no experience expects a Youtube video will show the truth about things :)
Weight is also an issue...
With a lead acid battery I really fail to see the need for a carbon fibre prop LOL
A wood or steel one would not really add much weight to the list...
Rick already gave you a nice link, but next time you build something you found on the web do some additional research before starting ;)
rickharris7 months ago
Your missing a lot of your list is all you have.
Goto
https://www.flitetest.com/getting-started
This will fill you in one what you need, how to do it.
This is possible the best RC flight site on the web.
