Question about using a L298N motor driver with arduino ?
I was looking at making a small rc tank with the lawnbots code. i have tryed small home built motorcontrollers and had seccus but thought It may be tine to build somthing better. I was looking at the L298N motor driver b ut dont have any idea what the EN_1 and EN_2 connections are for. Can someone please tell me? (Datasheet)
Thanks, David.
Feb 21, 2012. 2:34 PMiceng says:
Hi David,
Here is a better looking PDF of the L298
As Rick points out they are TTL High ( 4.5v to 5.5v ) Enable pins.
I like to view them as active low Disable pins.
To stop A or B or both outputs the two ENA and ENB are pulled to TTL Low
which the spec says is anything below 1.5v.
A
Feb 23, 2012. 11:41 AMiceng says:
If the motor is under 48VDC and draws less then 4 amps at stall.
YES you can run it of the Arduino logic pins.
Feb 21, 2012. 2:07 PMrickharris says:
The LN298 will drive 2 motor so everything is duplicated - EN stands for enable.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
