RFID Project Assistance
I am Software Engineer and need to build an prototype. Please can you recommend the hardware according the requirements specified below
    I have an Arduino UNO starter Kit here, also have an Arduino DUE
    The basics of the system are as follows:
    * RFID scanner (with buzzer if available) and Tokens required.
    * Display LCD/VFD/Serial, Need to have 16 characters x 2 lines.
    * Also need an PUSH button to control when the RFID needs to Stop/Start Scan - If its embedded in RFID/Display, my job is easier.
Regards,
jainvikas8
Feb 8, 2013. 11:54 PMiceng says:
Have a good look at this tweeting cat door.
A
Feb 9, 2013. 5:49 PMsteveastrouk says:
Try reading the section marked "Parts List".
Feb 10, 2013. 6:28 AMsteveastrouk says:
Parts list tells you where to buy the RFID module.
You don't tell the RFID when to scan: it does it automatically.
Feb 9, 2013. 10:59 AMiceng says:
Ask the author
Feb 9, 2013. 5:00 AMsteveastrouk says:
Try searching for RFID projects here. I think there is even a guide to RFID.
Feb 9, 2013. 5:51 PMsteveastrouk says:
I found hundreds. There are 10 projects on the right here.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
