RGB LED Bathroom shower light project problem. ?
I finished two bathroom reno's with the exception of the shower ceiling light.
I started off by cutting 3 1/4: square 304 stainless steel plates and drilled out 4 holes in each for the rgb. Then assembled the rgb's into the housings and sealed them with hot glue. Then figured out the resistors based on 12 V which if memory serves me right they were 470 ohms and soldered them in parallel. Then I soldered the connectors and hot glued them so they wouldn't come in contact with each other.
After installing the ceiling tiles I drilled 2 1/4" wide X 2½" deep holes through the kerdi membrane and sealed a plastic cover with foam insulation in the attic. Then I roughed in rgb cable from one hole to the other, with a home run to the controller.
I tried doing a rough in trial run and it worked until one of the rgb�s burned out since they came in contact wth each other. I could actually hear it fizzle.
Anyone have any suggestions on how I can make this work or are there retrofit rgb units that will fit the opening without breaking the bank? Each bathroom has 6 rough openings. That would make it 6 x 2 = 12.
I'd like them to be rgb leds and be controlled via 12V adaptor and controller. If I need to start over again I have a budget of $150.00 if a another unit would work better.
Thanks
My Dream (author) 4 years ago
Thanks for the reply frollard:
I'm curious as to how you would connect 6 of these in parallel to a controller?
Thank you so much for the reply frollard, I was starting to give up hope.
I did some more investigation and the leads of two of the led's did in fact come in contact as I could see them fused together. I did a test run before installing them in the shower ceiling and they ran well, it's when I enclose them in the confind space that creates a problem. My limitation is space.
I'm limited with space since I need to create a vapour barrier in the attic as well protect it from the insulation.
Below is the type of controller I'm using which is connected to a 12V 2a adaptor.
Although I've put many hours into this project, I'm wondering if I should cut my losses and go with something like in the second image, It's 1 7/8" wide and although pricing is much higher then the present project, should I considier it?
frollard4 years ago
Leds need SERIES resistors not parallel resistors -- that sizzle could reasonable be the led itself 'quitting'.
I would recommend a controller like:
hundreds of watts>rf controller
http://dx.com/p/rf-remote-touch-rgb-controller-130913
ten watts> IR controller
http://dx.com/p/10w-rgb-led-driver-with-remote-controller-100921
LEDS themselves, you can mount any leds so long as they run on the controller's voltage -- probably 12v. On 12v you generally want 3-4 leds in series on each controller channel for efficiency. Use a site like http://led.linear1.org/led.wiz to calculate the ideal for each r, g, and b.
http://dx.com/p/3w-150-lumen-waterproof-rgb-led-underwater-lamp-light-12v-46683 strikes me as a good idea, already waterproof. Just make sure they are wired common anode/cathode correctly for whatever controller you decide on.
