Rain Water Collection Filtration System?
1. a 2500 gallon in ground tank
2. 1/2 hp submersable well pump
3.simple float valve to maintain minimum water level during drought
What we are trying to figure out is to exclude purchasing a complicated expensive store bought filtration system we were trying as we always do to keep things simple. we have to provide sometype of secondary filtration system to aereate the water as well as clean it in order to run to our toilets.
Whatwould be wrong with using a small pool filter set in a 1 hour a day cycle that would provide oxygen to the water ? Also we were looking at using one of the floating chlorine tablet holders like a pool would use to maybe kill any pathegons that would be in it.
We realize this is too simple to not have some down side so all opinions and help would be greatly appreciatted.
11
answers
Answer it!
You want the tank in/on the roof, with a mains (float-valve) feed at let's say 25% capacity. Flush-toilets ought to drain enough volume that you wouldn't need to condition the water. If the tank runs low it fills (to 25%) from the mains.
L
I think I'd
a.) Make sure its DARK in the tank
b.) Aerate it gently.
c.) Make the tank as sealed as possible from insect life.
. As others have mentioned, if you don't plan on drinking the water, it doesn't have to be all that clean or sterile. You may need to do some disinfecting to keep the smell from getting objectionable.
. Investigate aquarium undergravel filters and other sand and/or gravel filters if you really need to do some filtration.
city hall handle 2 to 5 amps DC in each water to each tower and these
consumable 4 conductors are 8" long 2" wide 1/4" thick each. and must be
reverse polorised every hour. Water collecting roof tops also collect dust
of meteors in space that disintegrate in our atmosphere and dust to get in
the sludge which can be resold.
A
