loading
Remote Control Mini Heating Pad?
PLease I hope someone can answer this -
I am wanting to make a wireless remote controlled mini heating pad - this is the heating pad I want to use - https://www.sparkfun.com/products/11289
Would anyone know how i can make this very small heating pad wireless and with a remote to be able to turn on and off anytime i wish.
NOTE: The remote heating pad needs to fit inside a small object, almost as small as a playing card box - and be able to control the heat from the heating pad with the controller so it will not burn a thin layer of a cardboard box or paper.
If anyone can help with this, it will be greatly appreciated! :)
Picture of Remote Control Mini Heating Pad?
T0BY2 years ago
I think pucksurfer's idea is best. What do want to use it for?
iwseollc (author)  T0BY2 years ago
Thanks. im kind of a newbie when its comes to finding and wiring electronics, i might have to have china essemble this for me. lol - do you which an arduino, wifi module or a ir sensor i should get. I need to fit in a small box, which imention below as small as a card box - thank you for your help!! :)
iwseollc (author) 2 years ago
For steveastrouk: heat it up to / less then 5 minutes but to be able to control the heat where it does not get too hot of course...
For Downunder35m: and yes battery would probably have to be involved due to the remote control....
pucksurfer: that sounds like a winner? then wouldnt have to use batteries?
But note: Like I mentioned, this heating pad and remote control sensor needs to fit in as small as a playing card box (see attached)
How long do you want to heat it FOR ?
pucksurfer2 years ago
You could hook up power to an arduino and power the heating pad through the arduino, and then hook up a wifi module or a ir sensor and control it via your phone or an ir remote
I hope you are not asking for battery power as well...
-With the power consumption your option are limited on batteries.
You need a controller and remote that work on 5V or use 12V and a voltage regulator.
