Removing chlorides from a solution to leave only metallic copper?
7
answers
Answer it!
Doing a little research turned up a paper (Materials Letters 61, 2007, 1125–1129) with a procedure to produce powdered copper metal this way: "In a typical preparation of copper powder, 1000 ml solution containing 300 g CuSO4·5H2O and dispersion agent was added during 40 min to a stirred 2800 ml solution containing 250 g ascorbic acid. Aqueous ammonia was employed to control pH value. The temperature was kept 50 °C–70 °C for 2 h to carry out the reaction sufficiently, to reduce copper ion in the solution to metallic copper."
Their optimal conditions were two hours at 70 °C, with the solution at pH 6. They used gelatin to keep the power dispersed, but it sounds like that wouldn't much matter for your purposes!
The trick is to get the copper to precipitate in the wood.
How big/porous is the wood? Is there any possibility of inserting an electrode into the wood, to possibly drive copper into the wood via electrolysis?
what I'm trying to go for here is something that will steal the chlorine and precipitate out due to solubility issues and can take as long as it wants while leaving the copper in the wood. But if that doesn't work, how would I go about the electrolyses?
Fossilising might be easier if you try an impregnate it with minerals.
Dry the cactus out a bit, and make a hot saturated solution of a soluble mineral (traditionally, this means "epsom salts").
Soak the cactus in the solution, then dry it out.
More blue-sky:
Bore a hole down the centre of the cactus.
Stand the cactus in the solution, so that the liquid doesn't quite cover the top of the cactus.
Put a few drops of oil on the water, to slow down evaporation. Do not get any oil in the hole.
Dip a straw into the hole, put your finger on the end and draw the liquid out of the hole.
Hopefully, this will mean that the solution penetrates through the cactus, and evaporate from the middle of the cactus, leaving the minerals in the cactus.
I'd be much better off buying a silicate solution and following the more detailed processes I've seen written, and pyritization seems relatively simple too.
