3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Replacement electric razor foil
Does anybody know an inexpensive way to replace the surface foil on an electric razor? I think it's called foil anyway; it's the metal part that contacts the skin and is a mesh of small holes for beard hair to pass through. The raw foil stock must be relatively cheap to fabricate; maybe there is a way to get a sheet of it and put it on the original frame from the shaver.
Most replacements are almost the price of a whole new shaver. And I haven't even found a replacement for my modified, ancient Braun system 123.
After the shaver died I resurrected it and made it solar powered by tearing out the charge circuitry and batteries and replacing them with two batteries and a diode that plugs into a small solar panel from a garden light. This worked perfectly for years until the foil wore through last week.
Nov 6, 2010. 3:14 PMlemonie says:
The foils are expensive because you can't DIY to the same on the same money.
Get a new one or switch to blades.
L
Nov 6, 2010. 5:16 PMorksecurity says:
+1. Sorry, but this is almost a cliche in the advertising biz: "Give away the razor to get them hooked on your system, then make a profit selling blades." That's not as true for electrics as it is for blade systems, but they want their profit stream.
You could switch to a Norelco-like system. Those don't use thin screens, so nothing tears; the self-honing just stops being as effective. I've found the screen design gave me a slightly better shave, but that depends in part on your own face.
Nov 7, 2010. 1:35 AMlemonie says:
Blades for me, cheap blades...
L
Nov 6, 2010. 3:35 PMrickharris says:
I agree
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
