Resistor for Nano Arduino circuit
I'm trying to work out what resistor to get for the Nano Arduino circuit for this mini fridge build. From the photo it looks like a 5.6K 1%, but I have no idea what wattage? In the circuit diagram it is listed as 4.7K with no other details.
www.instructables.com/id/DIY-Portable-Mini-Refrigerator/
Any help would be great!
ggom2017 days ago
Any 4.7k 5 % or 10 % should do.The value is not very critical.
1 percent precision is not needed it is not analog signal line.
it is a one wire communication bus witch only needs a pull-up resistor
For more information:
https://datasheets.maximintegrated.com/en/ds/DS18B...
Regards.
And btw
+1 with Downunder35m:
Using a microcomputer, digital hight precision 12 bits sensor+power switches, for a fridge thermostat looks just a bit overkilling and costly too !
Anyway learning to use an Arduino is a great occupation.
And could lead you to many more projects.
Regards
gg
iceng18 days ago
Downunder is correct that is what I call a pull-up resistor and can be as small as an 1/8 watt resistor.. It's job is to make sure the Mini Arduino digital input D2 has a positive voltage such that the open collector thermal sensor circuit can pull down (change_voltage) at the desired temperature..
1/4W should do, it is just to get a clear signal from the sensor and no real power goes through there.
You can also use a simple and salvaged fridge temp sensor if you want to avoid all electronics.
