Resize 6mm platinum wedding band, reduce from 11 to 9.5
A jeweller will re-size a ring for you, and it shouldn't cost you much.
They will remove a section of the ring, in this case a couple of millimetres, and re-solder the ring back together.
They will use platinum solder so that your ring can be legally stamped, or retain it's stamp.
DIY is not a good idea if you don't have any experience with precious metals.
keydogstony5 years ago
If you don't want a jeweler to do it, there is a product  called Ring Guard Solution. It's a clear gel that will last a couple of Months.
Google Ring Guard Solution
Also an item called Ring Snuggies.
Here is a YouTube Video of Ring Guard Solution
rickharris5 years ago
Have it done by a jeweler! - Make sure you keep or get a cost reduction for the material they remove and (often) keep.
Kiteman5 years ago
I would recommend visiting a professional jeweller, due to the sentimental / emotional value of the ring.
iceng5 years ago
I know jewelers cut a segment out of a gold ring and remelt the ends
back together followed by shaping and polishing.
A
canucksgirl5 years ago
You can temporarily line the inside of the ring with layers of adhesive tape until it fits better, or get a jeweler to put a 'ring reduction bar' inside it, which isn't very expensive. However getting it actually resized smaller is a bigger job, and depending on the value of the ring, it might be best to have this done with a jeweler rather than a DIY method.
DIY ??
