Reversing saw to make a table saw?
The only saw I have used is a hand saw and not very much. I had really no knowledge of using it correctly. Since starting the this course I checked hand and found it was not set correctly. Main problem is setting blade to 90 degrees. I can get it set at 90 but only with the blade fully retracted. If I extend the blade I can only get 90 with the bevel grade set between 5 & 10 degrees.
Machine is old but I have only used on thick cuts, and I know machines history.
mikeasaurus8 months ago
If you plan on using a circular saw more, maybe it's time for an upgrade?
