Reviving lawn light solar cells.
Hello All,
I have several solar cells from old dead lawn/driveway lights.  Ultimately, I'm sure that it was the rechargeable battery that failed, but the solar cells are in some sorry shape, also.
While they have not been tested outside in bright sunlight, in my workshop, shining a high lumen flashlight (unsure of exact output, but it does reflect significant heat to the lighted area) produced less than 600mV.  The rechargeable battery is AA size (1.5 V).
The cell faces have heavy oxidation, which is going to block light, I know.  The cell faces are encased in some sort of clear epoxy/resin substance.  The connections are badly corroded, rust is evident around cell connections (which I found strange, but perhaps it dripped down from housing screws).  I know that the connections can be replaced somewhat easily, but what about the oxidation?  Without knowing what material is is encased in, how should I proceed in removing oxidation?
No flashlight can compare to the sun, I know this.  But even without a true solar test, I know that these cells will not experience optimal performance.
What can be done to revive these cells?
Thank you in advance for any suggestions!!  You all help me learn!
Huck
May 31, 2012. 5:27 AMknife141 says:
Semichrome metal polish is very good for removing oxidation and light scratches from plastic. I've used it on solar cells and on PDA touch screens with great success. Put a dab on a clean rag, rub it on aggressively, and buff with a clean cloth. Automotive headlight restorer will also work, but it only comes in a kit which would probably be enough for 10,000 solar cells. Semichrome comes in a small tube.
May 30, 2012. 2:40 PMJack A Lopez says:
There is a certain irony here, in that your plastic solar yard lights are being destroyed by the very sunlight which gives them life.
It makes you wonder:  If the darned things were intended to be used outdoors, why were they built out of materials that degrade in sunlight?
The answer to this question is that your solar yard light was not intended to last forever. More likely, it was designed to have a very short lifetime, with the expectation that when it does die after just a few years, that you, being a good consumer-zombie, will simply go back to the store and buy another one.  Ha!
But for some reason you feel cheated, and like Roy Batty, you WANT MORE LIFE!!!  For your solar yard lights that is.
I have often wondered if there might be some way to "harden" solar yard lights to protect them the most damaging component of sunlight; i.e. the high energy UV radiation.  It might be as simple as housing them inside a glass jar, although I have not tried this.
As far as fixing sun-damaged plastic... this sounds tricky to me, but I have seen some chatter on that subject, here:
http://www.ehow.com/how_8486195_repair-solar-cell-plastic-light.html
http://www.ehow.com/how_8035126_clean-fix-solar-light-cell.html
Jan 20, 2013. 9:13 AMpsychowoman says:
The glass jar idea is an awesome idea seeing how when people make solar panels, they house them under a piece of glass to protect them and they don't oxidate the way that the patio lights do... I found your question looking for ways to reuse the old patio lights that have stopped functioning myself... Thanks for answering the question as to why they stopped working in the first place. I may try to fix them now that I know...
May 30, 2012. 5:26 AMmpilchfamily says:
You can try buffing out the coating on the cells to take out any yellowing and scratch in them. You can get a buffing kit made fore car headlights that is made by 3M that works great. Comes with all the sandpaper and buffing wheels you need to do the job with a cordless drill.
http://www.amazon.com/3M-39008-Headlight-Restoration-System/dp/B001AIZ5HY
The oxidation can be cleaned up with a small wire brush. Reheating all the solder joint with a soldering iron will also help remove the oxidation.
May 30, 2012. 12:24 AMtstupple says:
You can wire a couple together to make a solar phone charger. All you need is 4 solar cells and a female USB plug. you need to wire 2 solar cells in parallel and 2 in series then connect to the 2 power cables on the USB plug
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
