loading
Running LEDs?
Quick question, really.
Anyone know if it's possible to run LEDs in series straight off of wall current?
For instance, lets say I have 60 2v LEDs connected in series. Could I just put 120 VAC into them (with the proper resistor of course) and they'd light up with no problem?
frollard5 years ago
technically, yes - but remember, 120vac out of the wall is actually 180 volts peak to peak (sine curve), so plan your voltage around the 180v.
There is an instructable or six about running leds on line voltage.
Beating head against wall now: It's dangerous, really dangerous, as line voltage tends to kill you.
Stick to the RMS value, IMHO, the 1.4 x RMS won't hurt, so to speak.
Yes, it can be done, but you have to be careful about the reverse voltage rating of the LED. Its a good plan to rate them for half as many LEDs, and wire two, anti-parallel strings - you only need one resistor.
Steve
