Sanding between coats results ?
Hey guys is it true using dryer sheets give u a better look and results than a tack cotton cloths
Picture of Sanding between coats results ?
mikeasaurus10 months ago
Tack cloths are slightly sticky (tacky) and are great for cleaning a surface. Dryer sheets are adhesive and might do a good job of cleaning, but a tack cloth is different. Whichever you use, neither is for sanding (as your question title asks).
A light sanding with a fine grit between coats helps reduce any bumps from a coating applied, and after wiping the surface with a tack cloth before applying the next coat will give a great finish.
