loading
Servo to shaft ?
Hello,
I would like to ask if there is a way to couple a servo motor to a shaft.
Thanks.
flonect (author)  steveastrouk4 years ago
That will be helpful. Thanks.
Don't forget to vote for the Best Answer. ;-)
rickharris4 years ago
1. A standard servo will only turn about 220 deg.
2. They can be modified fro 360 deg rotation.
3. If the shaft is much bigger or smaller then you will need to make a converter with the appropriate sized holes in it for the servo and the shaft.
4. If they are more or less the same join them with a short length of tight fitting plastic pipe. PVC tubing.
http://www.mindsetsonline.co.uk/product_info.php?cPath=418_6_75&products_id=695
Works well
What do you mean by a "servo motor" ? Do you mean a model aircraft type servo, or do you mean a real servo motor ?
Sorry about that, I mean model aircraft type servo.
http://www.robotshop.com/Images/xbig/en/hs-5765mh-hv-giant-scale-digital-metal-gear-servo-B.jpg
