3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Setting the intonation on a Les Paul?
How come, when all strings are in tune (using two different tuners to check) and the intonation at fret 12 is right on, strings 1,2,3,4 are fairly sharp when fretted on frets 1,2,3,4 then start to get back in tune?  Sharp enough that the guitar is unplayable.
May 5, 2011. 4:21 PMgmoon says:
Guessing here...
-- The nut is a little high, maybe. Or the nut isn't cut quite right...
-- In that vein, some luthiers set intonation at the first fret with a capo, not the nut. That way--the intonation isn't thrown off by any errors in the nut.
-- Familiar with the "buzz feiten" intonation method? Even without delving into it (or having a pro or con opinion), it seems that moving the nut a little closer to the first fret than the "correct" theoretical distance can compensate for steep angle the string must stretch near the nut. You can make (or buy) a nut with a little "overhang."
-- Try LSTune, it's like a stroboscopic tuner for your PC... I think it works better for intonation settings than most
Lemme now how it turns out. I've never been super happy with any setup I've had on my Les Paul...
May 5, 2011. 7:18 AMAvadhut.Deshmukh says:
set the intonation when setting up a Les Paul http://www.youtube.com/watch?v=YZEm0WOGJQU
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
