loading
Should I be worried about beryllium oxide poisoning?
From what I know, the magnetron in a microwave has some beryllium oxide on part of it, which is highly poisonous. I'm pretty sure the magnetron I dealt with had some (it was a pinkish-purple coating on the tube).  I didn't do anything to it, but I think some of it may have gotten accidentally scraped off with the screwdriver I was using to open up the magnetron.
BeO is a carcinogen and can cause CBD.  If some of it did indeed get scraped off (and I have no idea where it went, maybe into the air?), am I in danger of beryllium poisoning?
Kiteman5 years ago
"Exposure to fine, airborne beryllium oxide powder or dust in sufficiently large concentrations, may cause a lung disease in a small number of hypersensitive people."
[Link]
[Scarier link]
jesch1234 (author)  Kiteman5 years ago
First off, thanks for the quick response!
Secondly, I've seen those links, but I still have a lot of questions. There are a lot of qualifiers and no solid numbers there ("sufficiently large concentrations," "may cause," etc). I'm wondering if there's anything more specific about how much is a serious problem.
Personally, I wouldn't worry - it was a small amount that was released, and you probably took in only a small proportion of that, if anything.
Only worry if you get any symptoms you cannot account for, then explain your possible predicament to your doctor.
Great, thank you. I just called a poison control center to check, and they said essentially the same thing. Thanks a lot!
