Signal Indicator?
answers
Answer it!
If you get your tx to send out a digital signal to each receiver and you receiver immediately returns the signal the home base can measure the time difference between the signals to assess the distance the signal travelled.
Bearing in mind that radio waves travel at the speed of light - 3 x 10^8 then this time lag will be small for the short distances you are looking at but not impossible to measure.
Another possibility might be to use video cameras mounted up high to see where everyone is - there are programmes out there to interpret the video picture.
The transmitter would consist of a GPS module, a microcontroller of some sort, and a radio. The microcontroller would poll the GPS module at regular intervals for the position data, then transmit it to your receiver.
The receiver would have a similar setup, with a GPS module, controller and radio receiver. Possibly also an LCD screen. After all, if it's this complex already, an LCD is not so hard to add on!
Best of luck... hopefully someone has done something similar already, and you can borrow from their work.
