Slow Sulfurless Black Powder?
I have tried to make some sulfurless black powder by grinding 3 parts sodium nitrate (a potassium nitrate substitute, using this method to make it from ammonium nitrate) and 1 part charcoal (I tested it and it didn't burn good so I added more charcoal (probably making it a 2 KN03:1 C ratio)).  It burns extremely slow (if i laid a pile of the bp that was 1/8 inch wide and 1 inch long it would probably take 5 or more seconds to burn all the way).  I got the charcoal from a burned out bonfire (I don't know what type of wood it was but it wasn't willow or pine), I collected the black chunks that aren't all the way burned out.  I am wondering what the problem is, is it the charcoal or the sodium nitrate? The sodium nitrate is in its purest form, thats what it said here.
bahi2 years ago
sodium nitrate tends to get moisture very easy. Try using potassium nitrate. Try 70% saltpeter 40% charcoal ( from soft wood, dry straw...) use a not very roasted charcoal, like ancient people did, use "brown" charcoal. And use a ball mill, or if not possible mix it in tiny amounts in a mortar with a pestel and a few drops of water or alcohol. Works better if after that, you granulate the meal (powder from the mortar or mill ball) previously wetted, using a sieve.
bahi bahi2 years ago
Sorry 70% saltpeter 30% charcoal... You can add some powder sugar, 5% of the final weight (make the powder yourself, commercial powder sugar usually has starch)
lemonie5 years ago
Your sodium nitrate may be "crap", but do try grinding your powder wet, as a black-paste, then giving it a good drying-out.
L
electronicz (author)  lemonie5 years ago
I do wet the powder with alcohol when grinding it and then I let it dry before testing. I am suspicious of the oxidizer because I just made a new batch using the formula 14 KN03: 4 Charcoal: 4 Sugar. The KN03 I used was potassium nitrate
made from ammonium nitrate and potassium chloride, the charcoal I used was charcoal briquettes (the charcoal briquettes are not the purest but it would probably work better than ash), and the sugar was normal granulated sugar. I ground the ingredients separately in a makeshift mortar and pestle for about 5-8 minutes for each ingredient (I wet them with alcohol will grinding), I then mix them together with alcohol and let it dry. The outcome was even worse than the sodium nitrate mix. I will have to try to get some real potassium nitrate and test it out in a new batch.
get some real potassium nitrate - sounds like a good plan, I still think that's probably where your problem is.
L
Yeah, I will post the results if I get the KN03.
electronicz (author) 5 years ago
Ok, thanks.
