Soft circuit trouble?
So this is basically the same circuit that the xmas lights had but with conductive thread instead of wire. I double checked that there were no loose or crossed threads. After discovering the problem I checked the details about the conductive thread and it has a resistance of 30ohms/foot. The length of the thread connecting all of the leds is roughly 1ft.
So I'm guessing the problem is that there is too much resistance in the circuit? Or is there something else I'm doing wrong?
Is there any way that I can change this circuit so that it can still run on 3v batteries (2x1.5v)?
6
answers
Answer it!
Simplest fix: Make sure the wires to each LED are roughly the same length. If you've wired it as a spiral, replace that with a star configuration, with positive and negative stars all converging at a central point. You might need some "wasted" length zigzagging back and forth to make it come out evenly, especially for the LED(s) near the center.
Another fix would be to add resistors to the brighter resistors to dim them down until they're even with the dimmer ones, then increase the voltage to compensate.
If you want to stick with using the thread to connect your lights you need to make it more conductive. You can do that by adding a thin copper wire, wrapping it around the thread in a spiral. You can get the ideal wire for this by getting a cheap extension cord and striping the insulation off and using one of the fine strands of wire inside. The wire can conduct more than enough to run the lights and its very flexible so it can work with the thread. Its also fairly strong. Its one downfall might be if it flexes a lot over time it might break.
Its very handy wire and pretty cheap, you might find you can use it in a lot of ways.
