Solar charging a laptop, and issues with amps.
answers
Answer it!
Laptops present an "either/or" power scenario. By this, I mean that unless they see enough power at the source, they will ignore it completely and just operate from their internal battery. For example, let's say you have a 20W solar panel that on a particular afternoon is producing 15 watts for you. If your laptop is 'running', then it will likely need something like 30 watts, so it will consider the solar panel as effectively a "brown-out" and will ignore the panel and continue to drain its own internal battery. Laptops are not designed to take 15 watts from the source and supplement with the extra 15 watts needed from its own battery. They prefer to protect themselves. This is NOT a very good use of your solar investment!
There are two ways around this:
1. Only charge your laptop when it is turned off (so it doesn't have the same power requirements)
2. Use a solar storage battery between the panel & your DC adaptor. These batteries operate like a black-box power source, and will be able to take the 15 watts from your panel and add the extra 15 watts your laptop is wanting. This will also let you store power during the day for use with your laptop anytime, day or night. Effectively doubles your run-time too. Look at the Voltaic Generator Battery or the Brunton SOLO 7.5 as good examples.
One last issue to watch out for... Make sure that your DC adaptor does not have a minimum power input requirement, or you will not be able to go solar-direct from the panel to your laptop. For example, I have used a 65W DC laptop adaptor with solar, and it continually switches on & off if the solar power is weak.
There is an article on the solar laptop subject for further reading on the ModernOutpost.com website.
