3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Solid state tesla coil design?
Well, I am planning to build a solid state tesla coil. I've already build a spark gap one, but the amount of control over the output offered by sstcs looks more enticing. I have been looking at many different designs, but I think I want to go with a design based off of Richie Burnett's sstc.
http://www.richieburnett.co.uk/sstc01.gif
http://www.richieburnett.co.uk/sstc02.gif
Those are the schematcs. The first problem I'm running into is that he is running off UK mains, which are double the voltage from the US mains. Will the output of the tesla coil still be good if I am switching ~120v through the primary as opposed to the ~240v in the drawing?
Would this mosfet (https://www.onsemi.com/PowerSolutions/product.do?id=MTW32N20EG) work in the power stage, or should i get a higher voltage/lower current mosfet? I also need a substitute for the mosfet in the logic stage. Does it even need to be a mosfet? Could I replace it with a transistor?
The regulation circuit also worries me. Doesn't a linear regulator need to be fed a voltage of at least 2 volts higher than the output in order to function correctly?
I just realized how many questions I really had about it. Wow.
EDIT: I uploaded the pics for the sstc. The first two are the ones that I linked to, the third is Steve Ward's mini sstc. I was deciding between which one to use, but chose Richie's because Steve's has so many ICs and seems to be over-complicated.
Apr 30, 2011. 7:15 PMThe MadScientist says:
Just use a different step down transformer for the 120V to 12V 6VA.
Get a higher voltage lower current MOSFET possibly a IRFP460.
I wouldn't worry about the regulator I've used that regulator a lot I've fed it half the voltage.
And I am not sure what MOSFET you are talking about but don't replace it with a transistor it's probably not a transistor for a reason.
May 1, 2011. 12:59 AMThe MadScientist says:
That MOSFET is weird I'm not to sure.
Apr 30, 2011. 4:43 PMsteveastrouk says:
Try 36 turns on the Tesla primary.
May 1, 2011. 10:22 AMsteveastrouk says:
Change the turns ratio, to account for a lower input voltage. It IS just a transformer.
May 1, 2011. 10:38 AMsteveastrouk says:
A good point - just try it, I don't think you'll zap anything.
Steve
Apr 29, 2011. 5:22 PMRe-design says:
Well, I can't get your links to work.
Apr 29, 2011. 5:56 PMsteveastrouk says:
Strange, they were live last week.
Apr 29, 2011. 7:13 PMRe-design says:
Maybe they're design wasn't so good after all.
Apr 30, 2011. 6:21 AMsteveastrouk says:
No, I recommend his site - he knows exactly what he is doing. His theoretical analyses are always spot on.
When they are there....
Steve
Apr 30, 2011. 9:06 PMsteveastrouk says:
Hey, its not YOUR fault !
Apr 30, 2011. 7:34 PMThe MadScientist says:
Isn't this a little simpler?
Apr 29, 2011. 9:33 PMThe MadScientist says:
I was on that site last night but now it's not working unfortunately I don't have the images in the cache for the SSTC part of the site you might though. For the MOSFET question I doubt you could replace it with a transistor.
I can't see the schematic either, but you can modify the transformer design to work.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
