loading
Stepper motor
I have a small size sanyo denki 103 series stepper motor. I wanted to use it using L298 driver. What will be the connections
Picture of Stepper motor
iceng1 year ago
If you do not have a spec sheet on your motor, maybe you know how to use an ohm meter and label the color wires for the 6 lead unipolar connection.
See page 8
http://www.st.com/st-web-ui/static/active/en/resou...
Stepper motors use standrad connections, you can check this way:
http://goo.gl/0Occus
And then simply use a multimeter.
Otherwise check the datasheet ;)
