Stuck programming AVR or ARDUINO based 3 axis bipolar stepper controller.
Hello, I am writing a program to control 3 axis bipolar stepper motors using the atmega8 and other hardware (L293).
I am facing a mental block for the part of the program where I must switch the 4 outputs for any bipolar stepper motor.
I guess the program would explain the problem better. I can do this, but some innovative idea would be good.
I am also adding the circuit for the controller for reference.
/* 3-Axis Bipolor stepper motor controller. Takes 5 inputs
*  based on:
*  1) PD1 - Enable X axis
*  2) PD2 - Enable Y axis
*  3) PD3 - Enable Z axis
*  4) PC4 - Step
*  5) PC5 - Direction (Clockwise if 1)
*  Gives 12 outputs for motor control, defined as:
*  1) PC0 - MX-D
*  2) PC1 - MX-C
*  3) PC2 - MX-B
*  4) PC3 - MX-A
*  5) PD4 - MY-D
*  6) PD5 - MY-C
*  7) PD6 - MY-B
*  8) PD7 - MY-A
*  9) PB0 - MZ-C
*  10) PB1 - MZ-B
*  11) PB2 - MZ-A
*  12) PB3 - MZ-D
*  The uC reads the dir and step for each axis. Whenever step is
*  given a high pulse, step sequence is incremented (or decremented)
*  by one, depending on the direction pin's state.
*        Author: Pranav Sharma
*        Date: April 3rd, 2012
#define STEP_SEQ half_step_seq
#define STEP_PIN PINC&0b00010000
#define DIR_PIN PINC&0b00100000
#define X PIND&0b00000010
#define Y PIND&0b00000100
#define Z PIND&0b00001000
int dir=0;
int currentx=0;
int currenty=0;
int currentz=0;
int currentstep=0;
boolean enx=false;
boolean eny=false;
boolean enz=false;
void setup(){
  DDRB=0B00001111;    //B0-B3 Outputs
  DDRC=0B00001111;    //C0-C3 Outputs
  DDRD=0B11110000;    //D4-D7 Outputs
  PORTB=0;        //IS THIS NEEDED??
  PORTC=0;
  PORTD=0;
byte half_step_seq[]={
  B1010,
  B1011,
  B1001,
  B1101,
  B0101,
  B0111,
  B0110,
  B1110
void loop(){
  if(STEP_PIN)
    DIR_PIN?dir=1:dir=-1;
    if(X){
      currentstep=currentx+dir;
      currentx=currentstep;
      enx=true;
    else if(Y){
      currentstep=currenty+dir;
      currenty=currentstep;
      eny=true;
    else if(Z){
      currentstep=currentz+dir;
      currentz=currentstep;
      enz=true;
    byte stepbyte=STEP_SEQ[currentstep];
    if(enx){
      //step currentx time the x motor
    else if (eny){
      //step currenty time the y motor
    else if(enz){
      //step currentz time the z motor
    enx=false;
    eny=false;
    enz=false;
Picture of Stuck programming AVR or ARDUINO based 3 axis bipolar stepper controller.
It would make a LOT more sense to map the drive channels to nibbles, so PC0,1,2,3 = X 4,5,6,7=Y etc.
Does Arduino have NIbble addressable ports ? If it does, its easy, if it doesn't you need to use logical masking.
Create an array with the step sequence in it, use modulo arithmetic to step/index forwards and backwards through that with your X step etc counter. Use the contents of the array masked onto your signal lines.
pro2xy (author)  steveastrouk5 years ago
Okay.... so much so is sorted out...
I reasoned out that 0b1010 is the same as 0b00001010
This logic works well for X and Z axis with outputs on the lower nibbles of ports C and B respectively. On the other hand I have Y axis on the higher nibble of PORTD...
How do I sort this out now...
Make another step sequence just for Y axis??
I'd've mapped X to the lower part of B, Y to the upper part of B and Z to the lower part of C, leaving the upper part for other stuff.
PortD = Y data << 4 & X data
PortC= Zdata & 0x0F
but if you '...map X to the lower part of B, Y to the upper part of B' then it would become a little more complicated. On the other hand the PCB is already laid out 4 times :P
I didnt want to do that again
Hmmmm.... That makes sense. But I got the program working well enough. I'm waiting for some parts to arrive to check it out properly.
This is going to come as an 'ible.. :)
Thanks for the help steveastrouk..
I don't think it supports nibbles - I've never heard of it and arduino is the only uC environment I've programmed in...
The step sequence is there, its just a matter of applying a binary value to a port based on an index number.
Digitalwrite is okay, but slow when you need to address 4x3 pins one at a time, and the delay propagation might cause problems with the motors.
WHY did you scramble the mapping of the Z port ?????
It was all so easy before :-(
Steve
ummmmm... did I? Its the same... Z axis D,C,B,A = Port B 0,1,2,3
In your comments it says
9) PB0 - MZ-C *
10) PB1 - MZ-B *
11) PB2 - MZ-A *
12) PB3 - MZ-D
Oh! Im so sorry, that must have been a mistake.. Its DCBA.
I got the program running good. But one thing that is beyond me is that....
Mach 3 software gives 1 - 5 uSec pulses for Step and DIR.. Is this too short a pulse for my program to run well? I have breadboarded everything here and I seem to not get any pulse at all...
Its AWFUL fast for an arduino to pick up - I suspect its configurable in the Mach setup though
Yes. It is configurable. But only up to 15 uSec.
So this means that I HAVE to use a Stepper translator IC? Like Allegro A3982 or such?
I cant think of any other way for running bipolar steppers using mach3. Steve Baba you surely have some experience on this, dont you? :) I was just going through your workspace. And needless to say, I'm floating in dreams.. :P
Hi Pranav,
He he.
Yes, I know a fair bit about it.
Yes, a proper chip is the way to go here I'm afraid.
You've picked a good one, if it can handle the drive current you need for your steppers.
Steve
Yup! 2 Amps is plenty for me. The chip comes cheap. Requires very few components. What else do we need xD
Humph.. I would have loved to get the arduino to do this though. Never mind, maybe I'll think of a complete CNC on an arduino now.
Thanks for all your help! You're as wonderful as always. :) But something I didnt understand, is that observatory that I see on your website, yours?
Stick with the drivers doing what they need to do. The arduino can't compete in this application.
I built the dome and designed and built the doors for it.
This link may be of interest
Thats awesome! Unbelievable. I would love to meet you in person one day when I'm in UK next.
Do you get here often ?
Not too often. Once an year or so.
My dad's family happens to live near Northampton near london. He visits them often.
Only about 150k from us.
Grrrreat! :D
