Suggestions for simple scale drawing software?
I'm used to the archaic way of drafting floor plans ... T square + triangle + canary paper + pencil and eraser.  I need software that will let me make scale drawings on the computer. I've tried ProDraw and another trial, but all the 'helpful' stuff keeps getting in my way.   I don't want to drag every line around.
So does anyone know of a (hopefully free or inexpensive) simple grid & line & scale system that will let me draw the lines where  I want them to be?     I have photoshop elements 1.0 and love it.  But I don't see how to make scale drawings on it.   Thanks.
aeray2 years ago
Cad Standard by Apperson and Daughters. Cheap and easy. $35. Very intuitive if you are used to traditional pencil and paper drafting. I have been using it for years for fully detailed submit-able drawings for clients and building departments. There is no plug-and-play, though: WYSIWYG. Which is what I like about it.
mole1 (author)  aeray2 years ago
Perfect! And it isn't huge. Thanks so much!
EllieB24 mole111 months ago
Thanks all, I'm looking to do the same thing. Sadly Cad Standard (looks great!) but doesn't seem to download on a Mac.
aeray EllieB2411 months ago
I use an iPad for all of my other day to day stuff, but I keep an old Windows laptop around just as my dedicated CAD machine. CadStandard is small enough to run on a small cheapo laptop.
mole1 (author) 2 years ago
Hi samuel,
This works, but it's tedious:
This is assuming your drawing is proportional at whatever scale you want. say 1':1/2"
Scan it
Print it.
Use your scale ruler (engineering? architectural?) at the scale you want the drawing to be... say, 1':1/4"
Compare the length of a known printed line is supposed to be (say 10') to what your 1/4 architectural scale reads (if you're very very fortunate it will read 20').
Adjust your printing to the % required to make that printed line the correct length on your 1:1/4 scale. (In this case 50%)
Depending on your format and printer, it may take a number of tries to find the right 'page set up' settings. Margins or the lack of them can make a difference in some systems.
I hope this makes sense. ( I think I ended up printing things at 83.7% to finally get it right on one set of drawings.)
Let me know how it goes or if you find what you're looking for that's easy.
mole 1 plais do you have idee for this
al my drawings are like this bigger littel smaller ar there no softwear for this
can you help plais thank you
greeting samuel
mole1 (author)  samuel vermeulen2 years ago
Hello samuel - Are you trying to find how big the parts of the car are from these images? I don't know of any program that can do that from a perspective drawing. I don't know how to go from perspective drawings to dimensions by hand. I think it is possible, but I don't know how. A mechanical drawing teacher might be able to help you.
If you are just trying to show other people how big the car is, you could take another picture of the car with a meter stick on the floor between the wheels. You will often see pictures in (old) text books with rulers included to show how big or deep something is.
hello
i do want to know how bigg te car is
te dimensions i wanted to know what lengt of evry tube is
te drawings are exampel greetings
thank you I will look in to
greetings mole1
I dunno. Have you tried LibreOffice Draw?
I have had some had some success with this for 2-dimensonal vector drawings made of line segments, and boxes, and circles and stuff.
The x-y position, and size, of any element (line, box, circle, etc) you draw, these are properties of that element which can be edited directly. For example I want to draw a line segment, and then draw another line segment just like the first one, only shifted exactly 2 inches to the left. This can be done by copying the first line segment. Then editing the properties of the copy, specifically its x-position, i.e. adding 2 to the current position. That is, if the drawing is set up so the units are in inches. If each unit length is 1/4 inch, then you have to add 8, or something like that.
Anyway, I would NOT describe LibreOffice Draw as intuitive, or super-easy to use, or pretty, but I have been able to sort of beat my fists against it, and make it do stuff. Probably the thing I like most about it is its price, which is free. I never tried drawing a floor plan with it, but I can almost imagine someone using it for that.
mole1 (author)  Jack A Lopez2 years ago
What does 'vector' mean in the context of drawing? ?
The information in a vector drawing is stored as a list of geometric objects (e.g. lines, boxes, circles, etc), and the numerical properties of those objects (e.g. position, length1, length2, radius1, radius2)
In contrast, a raster drawing (sometimes called bitmap drawing) is just a width-by-height (e.g 1024-by-768) array of pixels, and the information in the drawing is just the color and brightness of each pixel.
The most useful property of a vector drawing is that it can be viewed at any scale, without loss of information; i.e. when viewing it on a raster-based device (e.g. a display or printer) the software just calculates the values for all the pixels, however many it has, for that device.
I think the following Wiki articles can maybe explain it a little better than I can.
http://en.wikipedia.org/wiki/Vector_graphics
http://en.wikipedia.org/wiki/Vector_graphics_edito...
Also
http://en.wikipedia.org/wiki/Comparison_of_vector_...
since you are looking to find an image editor for your thing. Who knows, maybe there will be something in that list that looks promising?
rickharris2 years ago
http://cad.about.com/od/Personal_CAD/tp/Five-Top-F...
May help you out - You can get autocad free as well - Pretty much an industry standard. If you want specific software for architectural drawing I think you may have to pay.
However nothing at all wrong with pencil and paper - often faster
petercd2 years ago
Inkscape is a free vector graphics editor which will have the ability to scale drawings but might require a fair learning curve.
I use Deltacad 2D for its ease of use, demo version here.
kelseymh2 years ago
On my Mac, I use the "standard" Unix program, |xfig|.
Most CAD packs will do what you need. Some are better than others with some being designed for drafting.
Google Sketchup isn't specific for cad drawings but has all the features you need and an easy to use interface.
