Switch button
I have connect Arduino with wave shield and 2 switch buttons to play wave when the buttons are pressed but it played it automatically with out any press and it repeat I don't now why ..
void loop()
  trackNum = findGPSLatLng();
  Serial.println(trackNum);
  // Get if a button was pushed
  buttonState1 = digitalRead(buttonPin0);
buttonState2 = digitalRead(buttonPin1);
  if(buttonState1 == HIGH && previous1 == LOW && millis() - time > debounce)
    audioSelectFlag = 1;
  else if(buttonState2 == HIGH && previous2 == LOW && millis() - time > debounce)
   audioSelectFlag = 2;
time = millis();
  //  here is the wave files to play
  switch (trackNum) {
    case 5:
    if(audioSelectFlag == 1  || audioSelectFlag == 2)
        playcomplete("1.WAV");
        break;
        case 1:
      if(audioSelectFlag == 1)
      else if(audioSelectFlag == 2)
        playcomplete("1b.WAV");
      break;
    case 2:
        playcomplete("2a.WAV");
        playcomplete("2b.WAV");
      break;
    case 3:
        playcomplete("3a.WAV");
        playcomplete("3b.WAV");
      break;
moonwa (author) 5 years ago
I have them declared before
int previous1 = LOW;
int previous2 = HIGH;
you mean like this
while (digitalRead(buttonPin0) == HIGH) {
switch (trackNum)
{ case 1:
Post the entire code not just the void loop.
I have them before
You mean like this
while (digitalRead(buttonPin) == HIGH) {
switch (trackNum) {
case 1:
etc..
mmm I will try to modify the code ..thanks a lot
For one thing "previous1" and "previous2" are never used in the code...
Also there is nothing stopping the switch statement executing. You should have a loop waiting for a keypress/ release cycle before the switch is executed.
