Synthesizer mod?
And i need a smooth volume control. during one of my youth groups worship session, i was on synth and
it went from quiet to loud WAY too quickly. so i would like to build a volume pot to output...but i dont know what the perfect requirements and setups are....any help on this?
9
answers
Answer it!
HERE is a very good description of a volume pot which would suit your needs. It's for an electric guitar, but the theory's the same.
You would have to get to the back of the jack socket where the output lead is plugged into and disconnect the connection to the centre pin. It may be a wire or it may be a PCB track which you'd have to cut.
Looking at the circuit on the page I've linked, you'd then connect the track / wire you've cut to the 'input' of the pot and centre pin of the jack socket to the 'output'.
Connect a wire to 'ground' which will be the outer ring of the jack socket and solder this to the case of the pot and pin 1.
Drill a hole and mount the potentiometer behind the control panel and add a knob.
Set the output level switch to maximum and then the volume control will give you from nothing to full volume. (You may have to swap over pins 1 and 3 if it works the wrong way round.)
