THE WAX IN SOLID PERFUME ?
DOES IT MATTER WHAT KIND OF WAX TO USE WHEN MAKING YOUR SOLID PERFUME,
Jun 27, 2010. 11:30 PMGottwinkies says:
Be brave! I would suggest Beeswax, though. Save the earwax for nibbling
Apr 14, 2010. 8:00 PMRavingMadStudios says:
It has to be earwax, or it won't work.
Apr 14, 2010. 5:26 PMkelseymh says:
You are more likely to get a response by posting this question as a comment directly to the I'ble you were reading.  You might also consider replacing your keyboard with one where the caps-lock key isn't stuck.
Apr 14, 2010. 4:15 PMlemonie says:
What is "solid perfume"?
How is it used etc.?
L
He's referring to the "related I'ble" http://www.instructables.com/id/Solid-Perfume/.
Apr 14, 2010. 5:25 PMorksecurity says:
If you're asking about the "solid perfume" instructable, I'd suggest asking in its comments section rather than here. (Though re-reading it might answer the question.)
I recently found out that lip balm sticks are made out of squaline -- which makes sense; that's the same oil that facial skin normally secretes.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
