Tadpole style recumbant - with the rear single wheel doing the steering with the front two wheels fixed - plausible?
17
answers
Answer it!
(As opposed to going the other direction, where the vehicle would tend to pull itself back into going straight. Or motorizing the forward wheels and letting the steering/rudder wheel's drag tend to pull it back into straight-line position.)
Possible, but maybe not plausible.
allow the rear wheel to move freely and control it with a stand alone break system for each front wheel.
example to turn right apply break pressure to the right wheel to turn left apply brake pressure to the left
but if you do it this way you wouldnt want to put the engine on the back wheel
HOWEVER There are good reasons for all rear wheel steering vehicles being relatively SLOW! -
At high speeds it tends to become unstable. At low speeds you are OK but find it hard to steer away from kerbs and walls.
There are loads of great resources on line for recumbent builders. I built mine 20 years ago and still rid it.
The motor is a good idea as the long chain run for a tadpole is a pain.
Some resources below.
http://www.google.co.uk/search?client=firefox-a&rls=org.mozilla%3Aen-GB%3Aofficial&channel=s&hl=en&source=hp&biw=&bih=&q=velomobiles&btnG=Google+Search
http://www.recumbents.com/home/
http://www.mosquito-velomobiles.com/index.htm
http://www.wannee.nl/hpv/abt/e-index.htm
http://www.google.co.uk/search?client=firefox-a&rls=org.mozilla%3Aen-GB%3Aofficial&channel=s&hl=en&source=hp&biw=&bih=&q=rear+wheel+steering+recumbent&btnG=Google+Search#q=rear+wheel+steering+recumbent&hl=en&client=firefox-a&hs=mUg&sa=G&rls=org.mozilla:en-GB:official&channel=s&prmd=ivns&source=univ&tbm=vid&tbo=u&ei=XFrXTcy7AsHPhAfLuP3CBg&ved=0CDAQqwQ&bav=on.2,or.r_gc.r_pw.&fp=ec64042ba2cabeca
http://recumbentsartandpoems.blogspot.com/2008/12/many-of-you-might-wonder-why-build.html
http://www.youtube.com/watch?v=v3lnRmSWKPE
They have the power going to the rear wheels with the steering constrained exactly to the vertical axis, and a long lever for the operator to adjust the steering - they do have ork's suggestion of instability at high speed when in 'pusher' mode, so you always have to drive 'forward' backwards dragging the load.
That's essentially how the writer Spider Robinson got started -- as he puts it, he had a job "guarding a hole in the ground to keep anyone from stealing it" -- which left him with lots of time to work on his writing.
