3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Temperature failure rating on certain materials:
I'd like to get failure temps for certain materials; IE, how hot something can get before cracking, exploding, ect. when molten metal is poured on/into it.
Would any of these last as a mould if you dumped hot lead, aluminium, bismuth and the like into them.
Hardened and cured plaster casts.
Quickrete.
Concrete.
Cement.
Ceramic mould.
Mar 17, 2010. 12:18 PMlemonie says:
Lead in plaster (well dried) would work the once, probably not much more than once though.
I'm not sure about the rest - what sort of things are you wanting to cast in which metal?
L
Mar 17, 2010. 4:52 PMlemonie says:
If you're casting that much metal, you should go with ork'.
L
Mar 17, 2010. 1:54 PMorksecurity says:
When sandcasting, you're making the sand mold from a positive. The mold is single-use, but the positive is reused as many times as necessary. Keeping it on file is no harder than keeping a mold on file.
Mar 17, 2010. 2:55 PMRavingMadStudios says:
I'd pitch all of 'em and use sand. Sand doesn't usually explode.
Mar 17, 2010. 2:48 PMBurf says:
I  would advise against Portland cement based materials. They are all hygroscopic in nature and the high heat of molten metals will turn the water into steam and cause the concrete to spall.  A ceramic mold however, should work fine.
Mar 17, 2010. 2:43 PMRe-design says:
One thing you must do whatever material you use for your mold is make sure that it is absolutely dry.
The melting temp of aluminum is 1250 f. or so and any water trapped in the mold will be instantly and violently turned into steam and your mold and molten metal will be turned into shrapnel.
Mar 17, 2010. 12:04 PMkelseymh says:
With composites and amorphous solids (all of the above), absolute temperature is less of an issue for failure as differential temperature.  These materials do not conduct heat well, so if you pour hot metal onto them you have very localized heating, while the rest of the material stays cool(er).  So you get differential expansion, and consequent fracture.
If you reduce the temperature differences, for example, by heating the mold itself slowly up to the work temperature, then you can avoid that problem.  You'll probably want to use refractory cement for such an application, for stability.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
