Testing a 3 watt LED?
I recently purchased 13- 3 watt LED's. I'm trying to establish a high out-put LED light.
I also purchased a LED Driver Transformer 48 Watt 120 Volt to 12v DC 4 Amp.
First I would like to test each LED using the same divider.
I'm thinking that if I create a voltage divider two 330 ohms to limit the current and reduce the voltage to about 6 volts that would allow me to test with the driver that I purchased.
Secondly, will this driver be enough to drive all my LED's and would I have to reduce the voltage down too since it appears to push out enough wattage and amperage for the total number LED's I'm putting together?
I'm building my circuit based on this video.
http://www.youtube.com/watch?v=4qYZahe2s5o&NR=1
Link to website data of 3 Watt LED.
http://ledsupply.com/indusstar-1up.php
Assistance would be greatly appreciated.
Regards,
Visit Our Store »
Go Pro Today »
I think the video isn't clear. The power supply is giving 670mA to between 9 and 12 LEDS, not 9-12V
If I were you, I'd have to consider a different supply I'm afraid.
Steve
I'm still interested in the tester though. I wonder if a 9 volt battery will do the trick?
Anyway, I don't want to waste my initial investment though.
This has been quite a learning experience for me.
Regards,
lancruz
If I were you, I'd try and get 13 x 3 volts to drive them, and use 40 volts to drive them, via a circuit like this:-
You HAVE to have current control of these LEDs or you will soon have 13 very small black spots.....
Steve
I did measure the voltage on the LED Driver. It is a DC power supply with a regulated 12 volts. The reason for the voltage divider is to reduce the voltage on a single LED to for testing purposes.
I do realize now that for all these LED's to work in series I need a bigger power source. I haven't figured out the right size though. I have an old PC that I can gut out for the 200 watt power supply and it's regulated, so that might work?
More detail on LED
http://www.ledsupply.com/driver-selector.php
I would still need a Power supply that will produce at least 32 volts though.
I wish this could be easier like details spelled out. I learn by doing and making mistakes as I go a long. I just don't want it to be a costly mistake.
I know my LED's are still good, and I believe I've found the right driver after our discussion
http://www.ledsupply.com/docs/36watt-lightech-data.pdf. Although this one seems to only work with 12 LED's in series. I believe I can make it work with this power-supply driver.
I'm still going to have a long discussion with LED Supply tomorrow to make sure they are on the same page as me.
Regards
LM317 - caveat: Fasten it to a GOOD heatsink !!! And if you don't, be prepared for it to get very hot very quickly.
If your PSU has a 5V output, with say 2 A of current rating it will be perfect for a single LED test.
Steve
I went to school many years ago for electronics and I'm trying to remember all the things that I learned. Cleaning out the Cobb webs so to speak. The main thing that the training taught me was to respect it and not be afraid to try and experiment.
This may turn out to be a good lesson for me.
Thank you.
Regards
Any questions, just ask.
Steve
http://engineeringshock.com/lm317-variable-power-supply-kit-diy-p-55.html
They haven't burned up yet. I'm letting it run for 24 hours. It hasn't generated any real heat.
Regards
I'm still working on drawing up the circuit from the kit I purchased on my original project. I've almost completed it.
Regards,
My project as far as I'm concerned was a success thanks to your help.
Regards,
Mark it as Best Answer please !
Steve
