This may be a real puzzler How do I build a tent around a suburban hatchback attached to a bumper pull horse trailer.
The bumper pull has a tack room located on the same side as the passenger side of the suburban. That tack room is loaded with tack, feed, hay and water as well and depending on the campsite a portable potty.
I would like to find a way to run a tent from the suburban back hatch,.over the trailer hookup to the trailer and encompass the tack room. So basically the tent would come off the back of the hatchback which I would leave open of course and most of the living walking and storage area would be on the passenger and tack room side.
this way I can enter from the side ....be able to insure my tack stays dry ..keep coolers and other equipment contained and still sleep in the suburban. One little thought is that I may need to close the hatchback and lock the suburban when we are all away from camp. although there is usually a camp steward who stays in camp.
Oh...Did I mention this has to be fairly easy because...1. I am pretty builder DIY limited even though I do give it my best shot and 2. During competitive events there is not a lot of time to set up for human needs as we are judged 24/7 those weekends on how we tend to the horse's needs.
THANK YOU SO MUCH
Visit Our Store »
Go Pro Today »
http://www.hutshop.com/10x20uncaana.html
It's not the most DIY of solutions, but it would meet your requirements of minimal building and quick setup. There are also larger garage-sized ones that you could just park the whole shebang inside, but those might take a little longer to set up.
I went to the site you suggested and they also have screen rooms Which might be the best solution. I can put one of those up against the trailer or suburban and have the extra room I need. Might have to configure a piece overhead using re-designs ideas to attach to the suburban and trailer to insure that no water leaks in when I have it up against the suburban. An extra roof if you will to insure that when it rains the water drains away from the living area.
I need to keep thinking and drawing designs. But while not entirely DIY it certainly helps with a solution. I think a huge horse trailer with live in quarters is the best solution <G> But kinda pricey between buying a truck to pull it and the trailer too.
Is this the kind of style of thing you are looking for ?
www.safari-equip.co.uk/index.php
Also some of the camping spaces are tight and narrow. Just enough room for a hooked up trailer and truck and some side space that allows room for the horse.
This configuration off the back of the suburban would be the ideal but I can't count on being able to do this at all camp sites. THANKS SO MUCH
Probably would help if I first take measurements of the two vehicles I am trying to build a tent around.
Thanks
I sleep on an air mattress in the back of the suburban so this configuration would allow me to keep all my camping gear under shelter and accessible. It allows head room so I can dress and enough room to put chair in and read ....Plus it allows me to watch the horse. The other thing I like about this is that I can put it on either side of the suburban . THANKS.
