loading
Tips for painting digi camo?
Can any one give me some tips on how to paint and make digi camo stencils, or direct me to where i can get some digi camo stencils cheap? Thanks.
orksecurity6 years ago
Well, you could draw a grid and paint every square by hand.... If the edges overlap a bit, or the lines aren't quite straight, that won't make very much difference.
(As requested, reposting as top-level answer.)
sailor496185 years ago
I cut squares of the blue painter's tape,spray ,dry,peal's off easy.
Worked good for me.
Good luck.
~Z~ (author) 6 years ago
Make a random comment so i can select you as best answer please.
Creative.. Might give it a try.
The best method I've seen is making paper sheets with squares cut out of them in a way that, stacked, there are no visible holes but separately there is a hole in every slot on a grid system.
~Z~ (author)  mettaurlover6 years ago
I can't cut well with an exacto.
Well, then, you have a bit of a problem using that method.
Exactly. Thats why i need tips.
orksecurity ~Z~6 years ago
Scissors work too, you know. And practice makes better.
