3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Tom Clancy's H.A.W.X error message: HELP!
When I click the little icon to run the program an error message pops up that reads "This application has failed to start because file D3dx9_39.dll was not found. Reinstalling this application may fix the problem. I installed it again and again and still the message comes. P.S yes it is a legal copy, I bought it for £20!
Jun 24, 2009. 11:48 AMRelaxedSoup says:
The reason this is happening is that Vista doesn't come with some of the older Direct X 9 dll's, so games that depend on them won't run. Fortunately, this is easy to fix, just download you dll here http://www.dll-files.com/dllindex/dll-files.shtml?d3dx9_39 and put in in your C:\Windows\system directory.
Jun 24, 2009. 9:30 AMkillerjackalope says:
I've had that happen with various programs before, a re-install should fix the issue, check the discs in good condition and clean, it should clear up the problem after re-installation. if it continues you may need to take it back and explain you've got a bad disc...
Jun 25, 2009. 6:59 AMkillerjackalope says:
Relaxed soup's found you an answer that looks good, try that...
Jun 24, 2009. 10:57 AMcheesemaker101 says:
download it on
then place it in ur system32 folder
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
